Layered brush paint problem
Trying to paint a model using the layer brush to create polygroups, following the tutorials for 3.5 in the document folder. However when I paint it doesnt fill the brush with the colour, only speckley, and im not using a spray stroke just freehand, tried dots to and it does the same. Heres a screen shot. Very confused, but im very much new to it! :confused: (the filled circle of yellow is where the brush is).
so…about that screen shot…
sorry, its there now :slight_smile:
Use the standard brush to paint your areas, then under Polygroups, group from polypaint. Or you can mask areas and then group masked etc. Painting with other than the standard brush may result in issues.
ah ok. thank you. :slight_smile:
