Hi, after restarting ZBrush my Layerbrush behaves odd. Although scaling z to 1 it´s raising as if scaled to 50.
Neither initialising nor resetting the brushes helps.
The pic is with z = 20 left side and z = 1 right side.
did you store a morph target first? that’s necessary to get the correct usage out of the layer brush
there’s also a layer constant brush that has been added to zbrush 3.5 that may help or you could try adjusting the brush curvature well clicking on the accucurve button underneath it so that it represents it more closely in the brush palette to give you a more accurate representation of what your going for. im sure there’s other ways but you may have to experiment a little.
Jepp, I´d stored a morph target - and transposed a little after that.
So of course the old store didn´t match the new surface and the result was my skyhigh layerbrush
Two clicks later ( DelMT/StoreMT) all runs correct.
Thx for your quick replys
