HI is their a way to make texture maps larger then 8k?
well i have done a vertex paint on my model aka colourise and want to take out texture maps larger then 8k any ideas ?
thanks in advance
sajeel shukla
thanks in advance
sajeel shukla
Not that I am aware of. Zbrush maxes out with images a little over 8k pixels square.
One has to wonder, though, what you could need with a texture bigger than 8k. I would have to think there is some sort of space management issue involved there.
well i am having an extreeme zoom into earth so i need to use minum of 10k x 8 tiles to hold up to the resolution for the movie i am going to output
Well, in that case, Im sorry…my thinking may have been too linear. Zbrush can’t create images of that size, but you can always create them externally, then import them into the texture palette, modify them, and re-export them. Depending on your system though, Zbrush’s stability working with an image of that size may vary.
thanks a lot for your efforts man
will give it a try
