Keyboard Map
Is there a graphic anywhere that shows the default hotkeys for ZBrush? I want to program some, but I don’t want to overwrite the defaults (at first, anyways.)
Thanks.
http://www.pixologic.com/docs/index.php/ZBrush_Shortcuts
Thanks… I’ve seen that, but I’m pretty visual, I was hoping there was a graphic version of that with the keys all charted out or somesuch.
I’m trying to program my Wacom tablet, I was hoping to assign some hotkeys that I can use with the little buttons on the side. I’ve managed to get most of 'em, but I wanted to assign some brushes to the rest, though that’s also proving to be a fiendishly difficult task. I can assign hotkeys to the brushes within the “brushes” popup, but not to just select the brush, if that makes any sense.
There’s no visual representation of the keyboard shortcuts.
To assign a hotkey to a brush:
  1. Put the Brush palette in the right or left tray so that it remains open.
  2. Select the brush that you want to assign a hotkey to. It will become the current brush.
  3. Ctrl+Alt click the small thumbnail that will now be in the brush palette and assign the hotkey. (Don’t click on the large ‘Current Brush’ thumbnail as this will change to a masking brush when Ctrl+Alt clicking it.)
Thank you, putting the palette in the tray and picking from there did the trick!
I was trying to do it from the pop up window and that didn’t work.
I was curious what all the default hotkeys for zbrush were as well and also wanted to view them in the form of a keyboard map so I could see what changes I make to the defaults when I plan my custom hotkeys. I put some time into making a quick and(Very) dirty keyboard layout in http://www.keyboard-layout-editor.com/
be warned however, this doesn’t take into account that zbrush has a number of context sensitive shortcuts that aren’t represented well with this layout and there are some click commands that Involve modifier combinations that I have omitted because they were starting to add too much complexity.
Zbrush Ctrl+Alt Hotkeys
Zbrush Ctrl+Shift Hotkeys
Zbrush Shift Hotkeys
Zbrush Ctrl Hotkeys
Zbrush Alt Hotkeys
Zbrush no-modifiers Hotkeys
