keep the insert brush when used in negative
Hi fellows!
Just want to know if it’s possible to keep your insert brush when used in negative mode (alt)…currently it disappears, but i want to know if there are a workflow for cut negative into the volume while keeping the insert brush used for cut…
it make sense??
This workflow will be really nice for toy making for example, when u make joints between cutted parts (for easy molding)
never tried and I don’t have Zinstalled on this system but you could try to duplicate the mesh before actually applying the brush insert. That should give you the same function.
You could also use the boolean functions that come with Zbrush instead of using the dynamesh options…granted, this is a little slower but it is how we used to have to do it anyway.
