just imagen (Zbrush 3D glasses)
what will happin if we can use Zbrush with 3D glasses ?
nothing you will see red and blue in your eyes. because Zbrush is not a Stereoscopic.
i was talking about what if Zbrush use the 3d galss
It would be cool and who knows? It might eventually be on the table as the hardware becomes more common. I don’t know one way or the other, and couldn’t say if I did. But let’s be realistic:
Modern 3D solutions require a 120 Hz monitor. Those aren’t that common yet. Additionally, you need something like nVidia’s 3D solution. But that is a hardware-rendered solution where ZBrush is a software-rendered program. So there would need to be a major overhaul of the rendering engine.
Additionally, to create the 3D effect you’re having to basically render twice as many frames. That means ZBrush would be able to push only half the polygons in order to maintain real-time rendering.
So there are some significant obstacles still to overcome.
Personally I’m waiting until ZBrush pushes a volumetric display of your model right out in front of you.:slight_smile:
in 10 year no one will have PC
but GC “Glass Computer”
There will be no more 2D screens and 2D images
i Know software call “ARTRAGE”
it is realistic draw software you can use real brushes and other things
i just imagine ZBrush 9 2020
you wear you’re 3D glass and you find clay to make into 3D model using you hand and tools like knife and hummer :smiley:
To mach HOP
