Join to objects together
Hi All,
I tend to do this quite often, I’ll start to mess around with just modeling the head but then decide i want to do the body as well, now I have ended up with two objects.
Is there a way to join these two objects into one ztool so the points are welded together on both body and head?
you can build a new mesh using retopo and then project both of the meshes onto the single new object that is one piece.
ok cheers so could i also export the head and body in 3ds max join them together then bring it back in zbrush and project the the two objects on the newly joined model.
Or do i have to do it in zbrush? b/c when i select the zsphere it wont let me after clicking on select topo any of the ztools with any sub tools in them?
:S
