I've many questions!
Hi there,
My name’s Andrea, I’m a 23 Yo Italian man! I’ve some questions to ask about ZBrush!
I’m using ZBrush 3.1 on windows XP system, well as if I use it on my laptop or on my “good performace” PC, Zbrush’s graphic is not so good… My 3d models’ edges seem to be uneven and shadows are low detailed…fair…
Where can I found an easy tutorial to use UVLayout with Zbrush?
Thanks a lot,
Andrea.
Regarding the rendering artifacts that you’re getting, it’s possible that you’re zooming the canvas rather than scaling the model. When a model is in Edit mode there’s an extra set of buttons that becomes available on the right shelf. Use those to scale the model, rather than using the bottons at the top of that shelf, which are always available. Those top ones are like scaling a Photoshop image, and will create artifacts as you zoom in.
