Issue with scale using "mesh from brush"
Hello!
Does anyone know if there’s a way to use IMM brush and retrieve the different parts using “mesh from brush” at the original size?
For some reason it always adjust them to fit the biggest subtool in my scene :(.
Thanks! :smiley:
BompAGoGo
You can try selecting the Polymesh3D Star tool in the Tool palette and then converting that to your brush but I think that you will always get the same size, and this may be larger or smaller than the ‘original’ size. I think the reason is that ZBrush scales the object when creating the insert mesh brush so that it is one unit in size (so it fits neatly into the Tool>Preview window). So when you use the ‘mesh from brush’ button it is this size that is used.
Thanks for the answer I will try that, and if it doesn’t work I will stick to my old method :).
