issue with notes
Hi everyone!
I’m new to zbrush so i’ve been watching tutorials and loving the power of this software, however i’m occasionaly getting snagged up when a ‘note’ pops up.
For instance: when i’m in the subtools palate and i attempt to delete a subtool, this note pops up saying ‘this is not an undoable operation press ok to continue or cancel to abort’
Sometimes it works properly and i can click on ‘ok’ or ‘cancel’ just fine… Although at other times the note will pop up, i can’t click any of the buttons and then it will just disappear (making it impossible to complete certain actions).
i did some reading and adjusted the preferences>interface>notes fade in-fade out time to a value of ‘1’ thinking that might fix the problem to no avail… I also tried ‘loadDefault zscript’.
(as i mess around with this more, the note seems to stop working properly when i go full screen on my video tutorial and then go back to zbrush to work…)
Has anyone else had this problem or have any suggestions to fix it?
Thanks.
the only true fix I know of is to restart Zbrush. It seems to think that “esc” is being pressed at all times…as far as I can tell.
For a quick fix, stop using fullscreen for your tuts if that is breaking Zbrush and your workflow.
I would submit a ticket to support to have them take a look into the problem though.
