I tried to get clever and use Micromesh to create an easy solution for Chainmail. While my insert mesh works exactly right, and can be used as a brush (with a LOT of labour and finnicky precision) I tried making a micromesh version with two problems:
The mesh is exactly scaled to the dimensions of the polygon on the main mesh. Is there a way to control the scale of this so each insert mesh is slightly bigger?
Is there a way to somehow force the mesh to weld point to point he say you can with a curve insert brush? “Weld Points” doesn’t really seem to do it unfortunately.
