Hello,
i have the following problem:
Imported meshes from poser are much smaller than unified mashes. When I try to work without unifiying before using for example the function QRemesher, I get problems with QRemesher with my small meshes, but not after unifying. For example, the mesh-polygon-count explodes after Qremesher from 2000 to 200000 also I have the option “same” or “halfe” polygoncount.
This does not occur, when i qremessh after unifying the mesh.
But for export of my mesh back to my other 3d-software, I would need the exact size from before unifying.
So my preferred workflow would be:
Import obj.
Unify
Qremesh
Work on the remeshed mesh
“Ununify” back to the original size
Export obj.
Is there any possibility to get back the original size after unifying?
mawag
