I wish to use the wacom setting in control panel to make clicking on the tablet with the eraser = ctrl+z for undo… no it maps fine (i use this in other apps) but zbrush seams to treat the eraser as if it is the tip of the pen so the keystroke command is like over written or something with a normal brush command… so the key stroke is not going into zbrush … but you can fully paint and stuff with it… If you disable it completly in the wacom tablet then clicking on the screen dose nothing… but as soon as you assign anything to the eraser then it will treat it like the tip of the pen.
q:- can you disable the eraser input inside zbrush?
