I have spent most of my graphic design days in Photoshop and I was wondering if there is a way to pull out guides similar to Photoshops ruler guides? Mainly is because I just trying to make things level to each other in different areas.
There’s no direct equivalent to Photoshop guides but the grid for the different axes gives a good way of judging things, especially when used with the axis projection lines. See the example in the attached file. Unzip it and place the ClearGrid.ZGR file in your ZBrush 4R4/ZGrids folder. It can then be loaded any time through the Lightbox Grids tab.
Much thanks for the info, I have to update to 4.42 still so I cant open the grid yet.
