Is there a way to keep the Curve Tube brush a uniform size while editing its path?
While working with the Curve Tube brush I need to zoom in and out and rotate around the curve to adjust its shape. But the size of the stroke drawn on the curve changes depending on the zoom level of the screen. Is there a way to turn this off? I would like to be able to keep the tube a consistent size while I am working on it. Any help would be greatly appreciated.
-Joe
http://www.pixologic.com/zbrush/downloadcenter/zplugins/
The adjust plugin can be used to store the draw size of the brush so that, as you rescale the tool zooming in and out, you can recall the stored size for a consistent result. I’m not sure if you’ll have to assign hotkeys to the store and restore buttons so that you can use them while the cyan curve circles are activated (I did during a test, and it seemed to work).
Thank you so much. That is very helpful.
