The title says it all. Is there a way to disable the Quick Menu while having the right click navigation turned on? I prefer to navigate in Zbrush with the right click navigation on. It gets kind of annoying when you sometimes want to navigate with the right click menu and then the Quick menu pops up. Is there some script that allows me to disable the right click Quick Menu pop up? I know that Zswitcher does something like this but I much prefer with the right click navigation turned on without the Quick Menu popping up every time. Thanks.
I too would love to disable the Quick Menu! Especially since it already occupies the Spacebar hotkey.
I don’t think it’s possible to disable it though.
You can almost stop it completely appearing by lowering the Click Time:
Preferences > Interface > Click Time
The lower the Click Time, the less the Quick Menu will appear.
However, if you set Click Time too low (0.01) you’ll lose the ability to use the Ctrl+Click Invert Mask shortcut and the Ctrl+Click Blur Mask shortcut, which is really annoying!
I find that setting the Click Time to 0.1 (or higher) re-enables the shortcuts, but at the expense of the Quick Menu randomly popping into view while navigating.
If anyone knows of a way to really disable the Quick Menu (through scripts or a plugin) please post!
