Is my texture supposed to look like this?
I am using Projection master and my source image is on the left. The texture file looks very desaturated (on right). I know I can tweak it in PS, but just wondering if it is supposed to look like this? My UV map size is 4096. Source image is an 8bit jpeg and texture is a .tiff. The image looks correct (in zbrush) until I pick it up in Projection master and then it gets dark… Thank you
Does it look correct when you use the flatcolor material?
thank you for the reply. it looks about the same. It seems to render ok in zbrush, but the colors look so light when I look at the .tiff file.
