You know how you can drop your polly painting onto the uvs and build a texture map… is it possible to do that the other way… load a uv’d texture map and convert it into a pollypaint?
wrong forum section and yes
right side texture panel and press txr to col
tool>texture>“txr>col”
Make sure you’ve divided the model to have at least as many points as the texture has painted/UV’d pixels.
