is better use projection master in higher resolution to sculp? or can I sculp in edit mode and have same result in the displacement map?
thanks, but I want to know if the displacement map that I´m going to export to xsi has better quality if I make it with projection master or if the quality of the displacement map only is afected by the final geometry.
