Is anyone else having a problem with ...
Texture Master in 1.5?
I get an error and then zbrush crashes and closes. :frowning:
Works fine for me…
Hi Dangerdave.
Some ZScripts from 1.23b need to be updated in order to work in 1.5 (mostly, those where an interface item has moved).
A revised version of TextureMaster is included with version 1.5. Please make sure that you are using that version. If the one included with 1.5 has difficulties, please contact me directly with as much info as you can provide.
Thanks!
Thanks for the replies.
Yes, Aurick, I am using the 1.5 version of Texture Master. I have unzipped 1.5 in another directory apart from 1.23b.
I will send you a note with the info.
If others are having a problem with this, please send a note to Aurick as well with as much info as possible.
While you’re online seeing as you are aware of how many emails you have could you perhaps give a rough estimate of when you might be able to send the download info out for those who used getsoftware. Will it be today tomorrow or next week? I’ve sent the info.
sunny lighten up on pixo they are a young company bear with them.
Hi, this is the info that I have sent Aurick.
Hello Aurick,
I am writing about the problem with TextureMaster that comes with version 1.5.
The following two errors happen when in open the TextureMasterRevE.txt zscript from the Utilities/TextureMaster folder.
Please note that the script does load and I can view the graphics and buttons and use the script, but it is when I click on the ā€˜Show and Tell’ button that the errors happen.
I am guessing that the ā€˜Show and Tell’ part needs some files or needs updating.
File Error
-Error has been encountered while trying to load a document file. Loading has been aborted.
[OK]
Zbrush
-Zbrush has caused an error in ZBRUSH.EXE. Zbrush will now close. If you continue to experience problems, try restarting your computer.
[Close]
Can some others please try the ā€˜Show and Tell’ option to see if you get problems as well?
Thanks
dangerdave, same problem here.
While you’re online Aurick, seeing as you are aware of how many emails you have could you perhaps give a rough estimate of when you might be able to send the download info out for those who used getsoftware. Will it be today tomorrow or next week? I’ve sent the info.
A ballpark figure will do.
Thanks for reporting Jack 1.
I forgot to mention that the error happens after being asked to reinitialize zbrush.
Sunny,
Please make your own topic.
It will draw more attention to it as you can make a more suitable heading.
Also, it will keep this topic on topic. It is about a problem with TextureMaster, not about downloading issues with people who used getsoftware.com
Thank you.
Dave, that’s when it happens here too. If I understand it correctly, it’s a text file on how to use it?
Jack,
Yes, it’s part of the zscript that has 5 awesome tutorials that I am constantly reviewing.
If you have version 1.23b in another folder, you should be able to see them. They are among the best tutorial scripts I’ve seen.
sounds like the ZBR is not loading from the show and tell.
if the texture master is in a folder by it self take every thing OUT and place each thing in the ZScript folder…
make sure your ZBR is in there all so along with the other stuff
Gee, I have the same error messages… however, going to my 1.23b TextureMaster, I get the ā€œthis is from an older file, it will update it on the next saveā€ worked fine then and even did the tutorials… :slight_smile:
I also have separated my zbrush1.5 folder from the 1.23b folder. So maybe some of the other scripts might work… will have to try putting them in the new zscript folder… :slight_smile:
:b4: SAME ERROR HERE AS DANGERDAVE :b4:
I get the same identical error as Dangerdave…same messages same routine
Try to put the ā€œTestureMasterā€ folder under ā€œZScriptsā€. NOT under ā€œUtilitiesā€. After I changed this it workes :slight_smile:
The same with the TexturePack.
Sorry,
after a newstart from ZBrush the Error was there again… Must be an other problem…
:frowning:
I get the same problem with Texture Master and Material pack… both seem to crash Zbrush! With Mat Pack, I have it copied in the main Zscript folder and still causes crashes when I try to scroll through textures.
OK, I did some poking around and I found that the TM-PANELrevE.ZBR provided with the 1.51 download is corrupt. If you copy the same file from you 1.23b install, then load and save it in 1.51, then the Texture Master ā€œShow and Tellā€ scripts should work. At least it did so on my machine.
  • Bob
