hello i having a huge issue with preference :utilities: view keyboard status
the value never reset to 0
i d like to track if ctrl or alt or any key get pressed at the same time we click onto a button/switch button in my plugin.
to make it acts differently. but no way.
the value there is never reset, after starting zbrush the value is by default set to 44
i press ctrl which should give 512, but it give 512 +44.
after you drop a polymesh then press T, the value goes to 116, so if i want to know if ctrl is pressed, i must to know first which was the previous value and substract 512 from it, then it would mean that ctrl is pressed.
what am i doing wrong ? or what wrong with Zbrush ?
same issue on R7 and R8.
Nicolas
edit : damn me, i can’t to edit the topic title to fix it.
