Interactive Light shortcut?
Heya, been trying to use the Interactive light a bit more, but the shortcut, Ctrl-P is being overriden by the masking tool when I press CTRL. Is there any way to get around this or to reassign the shortcut?
first off that sounds like your P key is not working properly or somethign.
also if you go into the light palette under placement you can click the P button and drag the cursor onto your canvas to where you want to place your light.
Ctrl+P does work for me. (You can’t be using a MatCap material, though, or you won’t see any effect.)
You can reassign the shortcut if necessary. Ctrl+click on ZPlugin>Misc>InteractiveLight, then assign whatever hotkey you want. Save your hotkeys in the Preferences palette before you’re done.
You might want to switch out of Edit mode to adjust the light. Ctrl+P is the Set Pivot hotkey also.
