Interactive Light not working in 3.12 - (answered)
I’m not able to get the interactive light plugin to work at all. It’s in the menu so I’d assume that it does work; is there a step I’m missing? I checked the wiki but didn’t see anything on it there either.
Thanks,
Thomas
Note that in order to use ZBrush lights you must select a non-MatCap material, such as the Fast Shader, in the material palette. The interactive light should then work. Should the hotkey not work try re-assigning by first clicking the button while holding Ctrl and then pressing the hotkey combination. Store your hotkeys before exiting ZBrush (Preferences>Hotkeys>Store).
