OK, several threads exist on this so I’ll be brief.
Zbrush 2.0 currently works on Mac Intel. Not official, not yet anyway.
I have had it running for some time now. Wonderful!!!
BIG CAVEAT HERE!!! Issues exist. So I’m looking for some guinea pigs to work through some instructions, and report back with specific info. This is to help others get up and going.
It’s pretty fast even under Rosetta emulation.
I am using a MacBookPro 17", 2GB RAM, Duo 2.16 processor and 100GB 7200 drive. OS X 10.4.7, now running 10.4.8.
At least 1 test machine cannot get Zbrush running at all!!!
Every other test machine can get it running, but has some starting Zbrush issues at varying intervals.
Has even been loadded and run on MacBook 13", 512MB RAM, Duo 1.83 processor and 60GB 5400 drive. Ran very well, but not the recommended system for sure.
G5 PPC Dual 2.5GHz single-thread test was 7.916 and multi-thread was 4.646 as a base test. MacBookPro Intel Duo 2.16GHz single-thread test was 16.91 and multi-thread was 9.3729 (under Rosetta emulation!) The best I had on my previous dual processor G4 1.3GHz was 11.4 threaded.
OK so if your in for a little mad scientist type stuff, here is what I’m asking of you.
a) Try Zbrush on your Intel system and report back.
b) So if you already moved Zbrush 2 to your system and got the license update you should be ready. If not test with the demo, until your sure and want to have a new license issued as per the instructions in your application folder 2.0 or 1.5 depending when you came aboard.
If you run the demo, just install and get the code from your email.
c) Report back with the following info (just copy an paste this section to your post here:
Processor speed:
Memory (MB) as supplied by Apple:
Memory (MB) installed afterwards:
Memory installed afterwards - Paired (Y/N):
Memory vendor:
OS X version:
Dev Tools installed?:
Anything else you can think might be relevant:
Success (Y/N):
Issues:
Opinion:
No. of tries before launch?:
After quitting, No. of tries before launch?:
OK NOW THE FUN PART!!!
So you get Zbrush installed by whichever process above. You start Zbrush, be PATIENT, it will take 40-60sec for Rosetta, Zbrush, memory, whatever to assemble in working order. Now if you try something, response should be immeadiate. If you get the super duper spinning beach ball you have discovered the issues that crop at random intervals! Foce quite Zbrush CMD-Option_ESC, select Zbrush. Wait 1 minute, yes 1 minute as it seems Rosetta doesn’t let go of her children all that quickly. Try again. Usually you are hot doggin in Zbrush by now. Otherwise repeat.
OK, so what happens if you get nadda? No start at all. Post your specs as listed above as I try to solve this with a few hearty and caring individuals.
So you are fully aware I have had Zbrush running under intel since the 15th of September. Almost every day, never crashed once, only had 4 times that had to be playful to get it running. Handles my large files very easily, 65MB the largest so far, still pushing to see where it lags. I think the solution is close, but it’s time for a larger test pool.
Thank you in advance for your help.
