Install zb4 to other directory?
Hi guys,
Hey I just installed zb 4 but I did not see an option to install to a different directory. Rather I wanted to install it on my slave disk which has over 3 times the available hd room on it. How does one do this?
If you have already installed and activated your ZBrush 4 installation you should deactivate the license first (ZPlugin > Deactivation). Then uninstall ZBrush 4.0
Now you can run the ZBrush 4 setup program again but this time be sure to select the Custom installation option when it appears. When you press next you can choose where to install.
The important thing to remember is to always return/deactivate a license before you uninstall ZBrush. That way you can reinstall as often as you like ( within certain limits, I am sure).
Hi TVeyes glad to know about you again! Taken your answer, i want to ask:
1.- i have one disc only to ZB, is that a good way(among other) to take the most utility from ZB?
2.-Is right?if yes, i will install the new version in that disc and not in the C default disc taken the custom installation…
Hope you are fine and thanks in advance
Thank you TVeyes,
I have not reinstalled yet, still playing with it for the moment. Alternatively however is there anything like being able to direct which disk ZB uses for virtual memory? Photoshop has a option like that, curious.
