Inside of nose sticks through the surface of the outside
How do I fix this? I have a nose and after using the move tool or sculpting brushes the inside of the nose sticks through the outside. How can I move only the inside stuff? I have a hard time selecting these parts.
Patrick
You might be able to pull this off with Backface Masking (found in the Brush palette). This allows your sculpt to only affect one side of a thin object.
If that alone doesn’t do the trick, try using the DragDot stroke type. Start your brush stroke on a part of the model that’s clearly on the inside, then move the cursor over the part that’s bulging through. Then release the mouse.
