InsertMesh Master
(Ver 1.2 Updated 9/5/2012)
InsertMesh Master helps speed up the process of creating InsertMesh brushes. It combines settings from the Stroke Palette and the Brush Palette together and allows for these settings to be set BEFORE brush creation!
This plugin is unofficial.
Main features
- Sets your InsertMesh settings BEFORE creating an InsertMesh
- Combines the most changed settings in the Brush Palette and the Stroke Palette
- Can also be used to change settings on an already created InsertMesh Brush
- Examples of some of the changeable options:
[LIST=1|INDENT=2]
Usage
Installation
UnZip the attached InsertMeshMasterV#.#.ZIP file to your \Pixologic\ZBrush 4R4\ZStartup\ZPlugs\ folder.
Restart ZBrush.
InsertMeshMaster will be located under the Zplugin tab.
Change Log
v1.2: Initial Public Release
Notes
After making quite a few InsertMesh brushes I decided to automate the process of changing the settings in the Brush Modifier Palette and the Stroke Palette. The settings that are on the tool are the ones I tend to set the most. If you find that you want any additional settings added let me know =)
Once again my Zscripting knowledge is average at best; if you find any bugs or other issues please report them in this thread.
Thanks!
-Joseph
InsertMeshMasterV1_2.zip (2.58 KB)
Thank you so much for your hard work and generosity.
small_orange_diamond
