I am trying to use Insert Mesh to join two tools into one.
The problem is that the tool I am inserting is moving out of its original position. I suspect this is something to do with it’s pivot being changed? Are there any ways around this? Thanks.
Mask or hide the original so that it can’t be affected. Then you can use deformations and TransPose to adjust the inserted mesh.
thanks for the tip, I’ll give it a go
its easiest to mask these issues by using polygroup hiding, if they are not separate polygroups use the AutoGroup function.
