I found a lovely tutorial on insert mesh (the one in the subdiv layer, not the brush which… just doesn’t work right for me ever). I decided to sculpt up a quick, multi-part piece to test it out.
It all combined well, but there were, obviously, seams. I held down shift to try to smooth and nothing happened. Then I chose the smooth brush, and nothing happened. Wondering if I had some strange glitch, I tested to see if I could draw on the combined pieces with the standard brush, which I could.
I decided to bypass the smoothing issue by just using the smooth deformation. I went to mask the seam, and it wouldn’t mask! NEITHER of the combined parts will mask at all.
Is this normal for using insert mesh? I was hoping to make the whole piece one mesh, then be able to mask and deform it to get poses out of the thing.
