I’m trying to use an InsertMesh brush with curve option to apply a mesh, repeated around the width of a cylinder. I sorta figured out how to use it but am just running into one problem. The mesh at the start of the curve does not join/merge/snap with the mesh at the end of the curve, although it comes very close. I’ve tried just about every setting I think. The ‘bend’, ‘stretch’, ‘snap’ and ‘weld options’ are turned on already.
Is there a setting or trick to have the two join? All the meshes along the curve seem to join up except for the start and end meshes. Is it possible to have them join automatically with some settings? or can it be done manually by moving etc only? I’ve attached an image from top view and have highlighted the problematic area in red circle.
