insert brushes?
for some reason when i watched the videos from Zbrush classrooms online, i came across a slight problem on the making of a screw for an insert brush. while they were creating a screw, they had to insert a cylinder as a brush and i don’t have that brush in my options. then later on i tried creating a insert brush from other videos and they all used a previous insert brush to make a new one. i don’t even have one to start out with. can someone please tell me what’s wrong because i am new at this and all i know is some of the basics :confused:
What version of ZBrush are you using? The version number will be in the top, left corner of the UI.
If your using the ZBrush Trial, which I believe is ZBrush 4.0, then that feature was not available yet.
