When I use an insert brush I seem to have an issue with it. I create a custom shape to insert, use curve to have it create a line of it, tweak it to my needs, then once I’m happy with the placement, and want to draw another, the first one disappears. What am I doing wrong?
Did you click on the mesh after you did the first one?
I’m not sure i did. I may not have. Thinking about it tho, doesn’t that just allow you to edit or redo the first mesh, and not begin a second?
I’ve read that a few times. I even watched the videos on the brush. They don’t exactly address the issue I’m having. When I place the first tentacle, lets say, then go to draw another, the first one disappears. It shouldn’t do that. That doc does say to hold ALT when drawing the second tentacle to adhere to the scale of the first, but doesn’t exactly address what to do if you don’t want to do that. Is it a bug in the program? Or am I not doing something correctly in the process?
Draw item, then click on mesh away from drawn item. Click and draw next one.
Thank you. I’ll try that.
