Dose anyone know how Paul Gaboury makes the insert plane brush work so well in the Fibermesh Tree 2 Movie found here http://www.zbrushcentral.com/showthread.php?165601-ZBrush-4R2b-ZClassroom-Movies#post927377
When I tried it and made my own insert brush it was really hard to keep it from either getting really long or stretched out. I did try holding the shift key while dragging out the insert plane brush that I made onto the tree leaves fibers but it didn’t help very much and had to really force it to not stretch out the plane.
Also most of my flowers came out upside down. I want to have a flower that has a backside but not up in the air while the open flower is stuck to the tree lol. I know I could either turn off double sided on the plane (well maybe) but then wouldn’t be able to see my flower’s backside, just make both sides of the flower the same, or rotate each plane after rendering one at a time.
Does the fact that he is so dang great at Zb make this look so easy or is there a setting I can play with in the brush menu to be able to constrain the plane more and the drawing of it?
Any help would be most appreciated thank you.
D
