Independent on zoom brush size?
Hi :smiley:
I’ve been wondering if it’s possible to maintain a brush size that would not be zoom dependent?
For instance, if I want to make some modifications when seeing the whole object on a certain brush size and then I want to zoom in but have the same size I had before… Currently as I zoom in, the size is a lot smaller than when I see the entire model.
Thank you!
Most people don’t use zoom when they’re sculpting, they use scale. If you do this, the brush size will be independent like you want.
db
marcus wrote a script that will store your draw size realtive to your model’s canvas scale. not sure where it is though.
That doesn’t work… if I scale the object same thing happens, the brush size doesn’t change according to the object size so it’s smaller than when the object is at its original size…
I want it !! :eek: No idea who Marcus is though.
