Impoting Alphas
Hi everyone,
I’m having trouble importing alphas. I have been working on a tileable mesh/texture tutorial, and can save the alpha to a directory of my choice, work on the alpha in photoshop, save it out, navigate to it in Zbrush… but when I select it, nothing loads, the sample is blank with the filename under it.
As a test I moved the file to the alpha folder where Zbrush looks for Alphas and can load it from there… After I close Zbrush, it won’t restart until I remove the alpha that I moved into its directory structure.
Any ideas… The tut I’m watching shows that the alpha can be saved and loaded as I would expect.
I am using ZB4R2, and the file is a PSD grayscale 16bits per channel, the size is 2048X2048.
Thanks for your time and help!
Go to Preferences > Performance and set ‘PreLoad File Size’ to maximum before you import the alpha. BTW, this is fixed in 4R3.
If your alpha is 16 bit and is 512 x 512 or smaller, then you don’t have to do this.
Thank you, this worked…! Is there a way to make this setting “stick”, or is this maybe the fix in r3?
Thanks!
Unfortunately, you can’t save that setting with ‘Save Config’ in 4R2b. You can in 4R3 though.
