importing multiple subtools at once
Hi, I’ve been trying to figure out the fastest way to export all my subtools at once, so I can do UVs, then import them all at once. I probably have close to 100 or so subtools. I just wanted to avoid importing each subtool one at a time.
thanks
sorry should of put this in a different section, but don’t see any way to delete it.
Are you using GoZ? If you have GoZ installed, you have the button next to the GoZ buton that says “Visible”. That will export all visible subtools at once, supposedly.
The SubTool Master plugin can export out all subtools but not re-import. Is there any reason why you can’t use UV Master to UV within ZBrush? Otherwise the simplest method would be to use GoZ with Maya or whatever.
Thanks for the replies. I tried using GoZ, and it starts to work. It opens Maya but only brings in a third of the subtools. The tools are not masked or anything. Is there a limit or am I missing something?
thanks
