How do you import .dwg files (AutoCAD or Solidworks) into ZBrush? Thanks
easy, you use something else to convert it to a .obj or .fbx
You can also try to use a goZ compatible program.
Great, so you’ve done this before? May I ask which software to use. I’ll check out the goZ
too. Thanks
Cinema 4D (already the ‘Prime’ version) has a DWG import function and there is also a GoZ Plugin available for C4D.
https://help.maxon.net/us/#FDWG
If you don’t want to spend money for an additional 3D program then you could try Bable3D, a online 3D file translation company.
https://www.babel3d.com/
CU and good luck.
This looks very helpful. I appreciate your time
This works very good for me, simple. The free account offers 100mb per month, I downloaded a chair leg with 2mb. Very good
thanks
You’re welcome
Glad to help you.
