Importing an Image...color change?
Hi, I’m new to Zbrush, and just playing around. I’ve recently run into a problem that I just can’t seem to get around! When I import an image (Document>Import), it’s color changes to a more saturated redish color. I’ve imported an image before and this wasn’t a problem. What’s going on? I’m using Zbrush 3.1.
Thanks!
Select the Flat Color material before you import the image. Document>Import fills the canvas with the imported image and whatever material is currently selected. You’re getting that effect because it’s the Red Wax material.
Ah! Duh! Thanks!
