Imported mesh- drag-rect' effects both sides
This has to be something simple (I am guessing)
When I import a simple model, lets say a standard box with UVs.
I subdivide.
throw lets say alpha 11 into alpha slot and set up drag rectangle as stroke type.
The star shape extrudes outward as expected, however, at the same time it is dragging outward from the front of the box, it is sucking the same shape from the opposite side of the box. (I’m not talking about symmetry)
It only seems to do this with drag rectangle tool.
What is incorrect ? Or rather, how does one avoid this from occuring.
Your help as always would be greatly appreciated !
Try turning on Backface Masking in the Brush palette.
Thank you very much aurick. As always, you are the ultimate zbrush knowledgebase. (Sorry, I couldn’t find this myself. I just wasn’t sure what to look for. I should have been thinking in Max terms eg… “backfaces”)
Again, Thank you
Best regards
