Imported mesh apear to show polygons not smooth enought.
Every model I import apears to show the poly edges even on render in zbrush. The same model in Hexagon or other 3d apps shows the model at same poly count smooth. The draw res in zbrush dont seem to have any effect?
58k polys
Make sure you’re not in quick mode, and then in the display section of the tool menu adjust the smooth (dsmooth?) slider until it’s pretty enough.
Ahh thats super thanks. Is there a way to apply this to droped objects as it apears that it only does this for active tools.
The exact path is Tool>Display Properties>DSmooth :slight_smile:
Quick 3D Edit is one of the switches on the top shelf, by the Polyframe switch.
