Hi, I cant get the import scaling to work.
I export my model from zbrush, i import that model after I joined the top and bottom half together in 3ds max and it comes in life a third of the size.
Thanks massively if you help
Try this:
Select the original one part model in ZBrush.
With the part model selected in the Tool palette, import the joined model you exported from Max. It should now come in at the correct size.
