Import multiple STL files at once as subtools.
Hello. Is this possible to import multiple STL files at once as subtools?
The problem is i have like 50 files, and it is not really fast to import all of them in sequence.
The SubTool Master plugin Multi Append or Multi Insert can import more than one STL file at a time. You can Shift+click or Ctrl+click to select multiple files in the file dialog. However, for STL import the plugin uses the 3DPrint Hub importer which names the subtool “Default”, so you’ll need to rename the subtools.
