Hi Thank you for the Script is it possible to Retain the Layers Name same as OBj File name?my Files have Underscore but when i import in Zbrush its Removing the Underscore from the Layer name.also is it possible for you to Increase the Number of Layers?i try to import around 700 OBJ Seq but its only importing around 200 something.it would be Cool if you can Update These in Script THank you
