Hello,
I’m looking for a way to import a Wavefront OBJ model, then scale it’s vertices.
I’ve managed to import it, but the scaling part doesn’t work. While in Edit Mode, I call this:
The Transform->Scale button gets activated, but my model doesn’t get scaled.
I’m not even sure if this is the correct way to do it or not.
I’ve also noticed that if you click Zplugin -> ScaleMaster -> Set Scene Scale, it gives the correct “generic size units” of the imported model. I want to scale the model down by 100, so Scale Master reports that the “generic size units” has also been scaled down by 100.
In other words, I want to scale down the model’s raw vertices. Is this possible? Thanks.
celess has made a mistake.
