Can I use a randomly cycling IMM brush to make a necklace strung with random beads?
Or am I limited to making random necklaces, each with identical beads along their respective strings?
You can set it up to cycle meshes in order, or randomly.
Check around the Brush: Modifiers setting (such as Multimesh Variation Selector Mode: 0=static, 1 cycles forward, 2 backwards, 3 for random)
But does it cycle within a single curve draw?
Or does it just vary the objects from one curve to the next curve?
It cycles along a single curve.
So far I can’t seem to get that to work.
I guess I will continue with my explorations, then. Thanks.
You need to increase the number of variations along with the variation selector mode.
As an example:
I sort of get it now. Thanks.
I’m not sure what I do that causes the whole thing to disregard my settings after a stroke and go into tri part mode.
