IMM not Welding when subdividing
I guess here is the best place to report this issue before than submit a ticket.
The case is IMM brush with curve mode and welding is working odd. Seems to work fine but when subdivide that shows the not welded vertex
Here you can download the Brush and the image
Hello
If you click on WeldPoints in Tool>Geometry>Modify Topology you will be able to subdivide with out the separation. Let me know if that helps.
Paul
Hi Paul
That helped a lot. But i might this does not weld all points along the curve. (I welded before subdivide…)
Any case thanks a lot i can try some curves before get the welded one working. Not a huge deal
Yes weld then subdivide.
