i will insert a part in my mesh: i freeze subdivision levels, use any imm and insert my part, but when i press the 2nd time freeze s.l. my part is very different (the shape is corrupted…!)
what is wrong in my workflow?
thx
thx
I cant reproduce your problem in a normal case. The mesh that you are inserting will be subdivided when use unfreeze subdivisions. If the insert mesh you are using has problems, as unwelded verts, inverted faces etc, the new subdivision can create problems.
Thx Altea…but i inserted a default imm parts…i think it isnt corrupted…i dont insert a part that i made! I solve the problem inserting a part in a copy (with zero subd) of my mesh, copied the part inserted and using it with the original mesh…
