Hello, I have this problem.
When I try to apply an IMM brush to a curve based in a Frame, the curve is ok but IMM result is wrong.
I know is a scale problem, but I don’t know if is possible to solve in other way.
Thx.
Thx.
Hello @Uky_Pum ,
This may be indirectly related to scale, but more directly caused by the resolution limits of the curve stroke process. If your mesh is abnormally large in the worldspace, what is probably happening is that a stroke of that size is resulting in a stroke that is too dense to complete. You would need to increase the DrawSize until you find a size that will complete. If the mesh is drastically oversized , disabling “Dynamic” mode in the Draw Size slider may help.
This video shows some of the problems that oversize meshes may encounter in ZBrush, and how to correct them.
