How can I make a stripe with no thikness?
Problem is that I can’t weld segments(I use plane as a segment)
You can use a plane as a tileable segment. Just create an IMM with a plane. Then active Curve mode in Stroke Palette>Curve. Then you need to say Zbrush to weld points and give some curvature. In order to do that go to Brush Palette>Modifiers. Active Weld Button and Curve Res slider higher than 1
thank’s! I should press stretch button also to weld points
