IMM brush size
Is there a way to drag an IMM brush over your model at a consistent size? Say I wanted to place a bolt head IMM brush all over my model at a consistent size. I know I could achieve this with a bolt head alpha and drag dot on a high poly model. But is there a way to do it with an IMM brush?
Apparently I’m also looking for a solution to this problem…but I found a work around for this, when using the IMM brush try pressing ctrl, it locks the size of the component to its original size…so if the size of the brush gets too small try resizing the model…hope it helps…
Thanks, that is helpful. Holding ctrl works pretty well, and the size is affected by the brush size, not the original model apparently. Though it would be nice to be able to drag it around before placing it, without having to do it manually after. Holding spacebar does move it around but it doesn’t follow the models normals.
You can’t do what you want. What you can do is duplicate the IMM mesh in a new position by pressing Shift+1. Obviously that leaves the original rather than moving it but you may find the method useful for placing rivets etc.
